notfallenyet Posted November 23, 2008 Report Share Posted November 23, 2008 Hi Folks, have a problem with my 1999 TXT270 seems to be getting air from somewhere other than through the carb. I have already cleaned the carb but at low revs the engine runs very erratic. Will check the following tonight; Carb to cylinder rubber and crank shaft seals. Anyone got any other suggestions? Quote Link to comment Share on other sites More sharing options...
postmanpat Posted November 23, 2008 Report Share Posted November 23, 2008 Hi,my in-law had a TXT250 that had a similar fault,there was a fine crack in the rubber connection on the reed block to carb,just run a fine bead of superglue into the crack......his problem went Quote Link to comment Share on other sites More sharing options...
