2007 270 Beta Running Badly?
jonny186
I own a 2007 270 beta, its done very little, I seems to run spot on one day then the next time I try it it seems to run weak on the mixture and start to knock now and again. Ive tried all sorts with the carb, different needle setting / mixture screw etc, Ive just fitted a brand new stator. Can anyone else help here? any idears as its driving me mad! Thanks Jonathan ;)
Better gas will stop a lot of beta knocking.
#27.5 pilot jet and needle second notch from top makes it run smooth.
Check the air screw is adjusted for best idle speed for the day (approx 1.5-2 turns out).
Check carb connections and gaskets for air leaks
Always run a clean and properly oiled air filter.
AND then put up with what is left. Ralph
Ive had the carb in bits a few times, absolutly spotless no water or dirt, Ive put the kill switch earth onto the main frame were the coil earth goes on, Ive got a feeling it might be suckin air in on the reed valve, Im goin to try and seal this it and try it this weekend, Fingers crossed, Jonathan
