Nasty Whirring Noise
unbalanced
Best thing to do is drain the oil and water remove the kickstart and the brake lever. Remove the bottom water hose too. This will expose the kickstart gear. from there you should be able to get a better idea of what the problem is. I would expect that when you drain the oil it will look like metallic paint.
