unbalanced Posted November 30, 2008 Report Share Posted November 30, 2008 Whacked a rock right on the kick start shaft, then the nasty whirring noise started. Bike started and ran but making hideous noise. It was exiting the last section so just rode it back 500 metres to the van. Any ideas? Quote Link to comment Share on other sites More sharing options...
godzilla Posted November 30, 2008 Report Share Posted November 30, 2008 (edited) is it an sy2t? Edited November 30, 2008 by godzilla Quote Link to comment Share on other sites More sharing options...
unbalanced Posted December 1, 2008 Author Report Share Posted December 1, 2008 Yes it is. Quote Link to comment Share on other sites More sharing options...
godzilla Posted December 1, 2008 Report Share Posted December 1, 2008 Best thing to do is drain the oil and water remove the kickstart and the brake lever. Remove the bottom water hose too. This will expose the kickstart gear. from there you should be able to get a better idea of what the problem is. I would expect that when you drain the oil it will look like metallic paint. Quote Link to comment Share on other sites More sharing options...
