gazzaecowarrior Posted December 2, 2008 Report Share Posted December 2, 2008 Hi there. My Beta Rev 3 rear wheel is losing air from the spokes. I had this problem rectified a few months ago and it cost me Quote Link to comment Share on other sites More sharing options...
stork955 Posted December 2, 2008 Report Share Posted December 2, 2008 Gday, my Techno rear has had a tube in it for over 3 years, no problems, apart from a valve cap failure... Mind you I ride the back end of C grade so Im not that hard on the bike. You still need to cover the spokes up with a rim band or tape etc. Cheers, Stork Quote Link to comment Share on other sites More sharing options...
mjb Posted December 2, 2008 Report Share Posted December 2, 2008 gazzaecowarrior, I've been doing this for years iwth my rear tyres for 2 reasons 1. Its the only way I can get the tyre on the rim with my old compressor. 2. Same experience as you my rim always leaked even after silicone and rim tape. If your really worried that the tube may take some abuse you can always gey a heavy duty inner tube. Quote Link to comment Share on other sites More sharing options...
grahamjayzee Posted December 2, 2008 Report Share Posted December 2, 2008 gazzaecowarrior said: Hi there. My Beta Rev 3 rear wheel is losing air from the spokes. I had this problem rectified a few months ago and it cost me Quote Link to comment Share on other sites More sharing options...
scorpa3 Posted December 2, 2008 Report Share Posted December 2, 2008 A tube in a tubless tyre is fine, the tyre won't slip around and the tube will be ok. But if you ever get offered a tube tyre don't try to fit it on a tubless rim. That will slip round. Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted December 2, 2008 Author Report Share Posted December 2, 2008 Thanks for all your advice. I think I will go with the heavy duty inner tube and say goodbye to these air leaks. Any more advice will be welcomed. Thanks. Gaz Quote Link to comment Share on other sites More sharing options...
timp Posted December 2, 2008 Report Share Posted December 2, 2008 Why not just fix the problem. Take off the rim tape and clean up the rim. Put plenty of grease on the rim covering all the spoke ends and coat the underside of the new rim tape and replace. Some will recomend using Sikaflex to stick the rim tape on instead. The choice is yours. Beats messing with a tube and your tyre performance will be improved. They are made tubeless for a reason!! Quote Link to comment Share on other sites More sharing options...
gizza5 Posted December 2, 2008 Report Share Posted December 2, 2008 (edited) Timp said: Why not just fix the problem. Take off the rim tape and clean up the rim. Put plenty of grease on the rim covering all the spoke ends and coat the underside of the new rim tape and replace. Some will recomend using Sikaflex to stick the rim tape on instead. The choice is yours. Beats messing with a tube and your tyre performance will be improved. They are made tubeless for a reason!! Agree fix the problem, do a search on the forums there has been plenty of discussion on this topic with plenty of knowledgable people with different ideas some may work some may not! There are several solutions to leaking rims and all have been discussed; me personally I have used Sikaflex in the past with 100% success. Edited December 2, 2008 by GIZZA5 Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted December 2, 2008 Author Report Share Posted December 2, 2008 Timp said: Why not just fix the problem. Take off the rim tape and clean up the rim. Put plenty of grease on the rim covering all the spoke ends and coat the underside of the new rim tape and replace. Some will recomend using Sikaflex to stick the rim tape on instead. The choice is yours. Beats messing with a tube and your tyre performance will be improved. They are made tubeless for a reason!! I appreciate your opinion but the reason I want to go for a tube is more economical than performance related. I don't have a compressor to inflate the tyres to get them to sit on the rim and my local shop charges me Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted December 2, 2008 Report Share Posted December 2, 2008 gazzaecowarrior said: I appreciate your opinion but the reason I want to go for a tube is more economical than performance related. I don't have a compressor to inflate the tyres to get them to sit on the rim and my local shop charges me Quote Link to comment Share on other sites More sharing options...
peterb Posted December 3, 2008 Report Share Posted December 3, 2008 Hi there, I agree that it is best to fix the leak problem - at home should be possible. I have twice managed to bead out a tubeless tyre (on a GG) with a high volume hand pump (I was amazed, only managed with a foot pump before). Thorough cleaning usually works well before assembling, then try the Sikaflex. Check for leaks with a bowl of soapy water and a brush. If you do fit a heavy duty tube, the only problem is when you smack into the edges of larger rocks, where you can nip the tube and get a compression puncture. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 3, 2008 Report Share Posted December 3, 2008 If you decide on a tube the dunlop 803 works well. Stay away from the IRC because they spin slightly. It is the 'easy' fix. Quote Link to comment Share on other sites More sharing options...
grahamjayzee Posted December 3, 2008 Report Share Posted December 3, 2008 I've always managed to seat a bead with a double barrel footpump and tyre soap as long as the rim is nice and clean. However, I have just bought a compressor. There is a bargain to be had at Screwfix at the moment that I'm siure is a mistake, so fill yer boots lads! http://www.screwfix.com/search.do;jsession...fh_search=95294 I got mine yesterday and it really is a 2HP compressor and it really did come with all the tools, and they really did charge me less than 60squid... Quote Link to comment Share on other sites More sharing options...
betabonkers Posted December 3, 2008 Report Share Posted December 3, 2008 gazzaecowarrior said: I appreciate your opinion but the reason I want to go for a tube is more economical than performance related. I don't have a compressor to inflate the tyres to get them to sit on the rim and my local shop charges me Quote Link to comment Share on other sites More sharing options...
