somerset steve Posted December 9, 2008 Report Share Posted December 9, 2008 I need to install a kill switch on my 200. Which of the 3 cables that come off the management unit do i need to ground to earth through the kill switch? Steve. Quote Link to comment Share on other sites More sharing options...
hop blip and a jump Posted December 9, 2008 Report Share Posted December 9, 2008 Usually its easiest to cut into the wire going to the top coil and the other to an earth on the frame, so it shorts the coil. Quote Link to comment Share on other sites More sharing options...
lee harris Posted December 9, 2008 Report Share Posted December 9, 2008 Hi Steve, if you have a dansi coil, connect the red wire to one side of the kill switch and the other to ground. If you have a ducati coil, still connect the red wire to the killswitch....smartar$e harris ,-)))) Quote Link to comment Share on other sites More sharing options...
somerset steve Posted December 10, 2008 Author Report Share Posted December 10, 2008 Ta for that. How do i tell what coil is fitted. It is a black box under the tank, has HT lead out at front end, 4 spade terminals at the rear. Box is 100mm long by 50mm heigh. Quote Link to comment Share on other sites More sharing options...
lee harris Posted December 10, 2008 Report Share Posted December 10, 2008 Thats ducati, the original dansi was a round ali can. Wired slightly different, mail me if you need one wired, but ok L Quote Link to comment Share on other sites More sharing options...
