Gasgas 300 Speedo
hamster
You want to unbolt handle bars and the three pinch bolts on the top clamp. then undo the middle top nut
so you ca get the top clamp off.Then the speedo will come off.
I found a washer the same thickness as the speedo brakett and then bolted in all back together.
The wire for the kill swicth is the yellow and black wire comeing from the CDI box and a earth wire to
the back off the coil. gas gas wires
Did your speedo work ? was it in miles per hour or KPH???
Good luck, its not a hard job to do and worth it....
