hamster Posted December 11, 2008 Report Share Posted December 11, 2008 hi all can any one offer some advice on removing the speedo on my 2006 300 want to put a kill switch on but can't seem to find any threads relating to removal of said speedo cheers in advance Quote Link to comment Share on other sites More sharing options...
toofasttim Posted December 11, 2008 Report Share Posted December 11, 2008 Oh heck, can't really remember. I just unplugged everyting until I was left with what I needed. I bought a KDX killswitch but can't remember where I plugged it in. PeteB will be able to tell you (he told me where to connect the killswitch). Quote Link to comment Share on other sites More sharing options...
mikee Posted December 11, 2008 Report Share Posted December 11, 2008 You want to unbolt handle bars and the three pinch bolts on the top clamp. then undo the middle top nut so you ca get the top clamp off.Then the speedo will come off. I found a washer the same thickness as the speedo brakett and then bolted in all back together. The wire for the kill swicth is the yellow and black wire comeing from the CDI box and a earth wire to the back off the coil. gas gas wires Did your speedo work ? was it in miles per hour or KPH??? Good luck, its not a hard job to do and worth it.... Quote Link to comment Share on other sites More sharing options...
hamster Posted December 11, 2008 Author Report Share Posted December 11, 2008 thanks for the reply's it is the wiring i'm more concerned about seem's to be a lot under there will give the wiring diagram a go Quote Link to comment Share on other sites More sharing options...
hamster Posted December 14, 2008 Author Report Share Posted December 14, 2008 done it not as complex as i thought thanks for the answers guy's Quote Link to comment Share on other sites More sharing options...
