2008 Sherco 290 Rear Shock
hagan10
It is usually neccessary to adjust the spring after it settles.
I run mine to where the rear will settle about 20-30mm under its own weight(bike only, no rider).
This could require 3 or more turns of the adjuster ring. :guinness:
there is also a dampening adjustment located from the left side just past the chain tensioner, start it at 5-6 clicks out or counter clockwise. turning it in will increase dampening.
cheers
cheers
I thought that was only for rebound dampening??
Best of balance.
Neo
