mcman56 Posted December 13, 2008 Report Share Posted December 13, 2008 I removed the small end bush from my C15 and the surface finish inside the rod is really rough. It looks like a very bad drilling job. As far as I can tell, it is pretty much round with an ID of .751/ .752. Is this rough surface normal or common? I'm thinking it needs to bored for an oversize bush but don't want to bother if this is actually normal. Quote Link to comment Share on other sites More sharing options...
nigelog Posted December 15, 2008 Report Share Posted December 15, 2008 Hi Dave did the same jod on mine and it was not rough. I will check dimensions and get back to you to see if you can avoid an oversize bush. Ta Nigel Quote Link to comment Share on other sites More sharing options...
