Removal Of Autolube Repalcement Bung
nicbrrghs
I don't think Yamaha make a replacement part but you can do as Swooshdave suggests or make your own. The easiest is to fill the two holes and slit with black silicone, allow to dry and then shave off the excess. You can make one to fit from any old windscreen beading which has the grooves already cut in the rubber and this can make a good professional looking part. Don't forget to seal off the cable hole at the front with a bolt or bung. Finally having got shot of the autolube use a small vacuum rubber on the inlet on the carb.
Tony
