Cylinder Replate Or Re-sleeve?
hop blip and a jump
I'm not sure where a liner is going to take you. I've just had two Hiro cylinders re-plated and although I'm slightly disapointed about the quality of the plating the fit of the piston and finish around the ports is spot on and it means the cylinder is as per standard. I let the platers have the piston and match the bore up to that. Has your piston turned up yet?
Where did you get the cylinder replated..???
Yeah, the piston and gaskets/seals turned up late yesterday.
I think i'll get it re-plated.. :huh:
