max Posted December 21, 2008 Report Share Posted December 21, 2008 Hi, Apologies if this is a stupid question but does anyone know where i can get a maintenance / service manual for a '93 Beta Zero/Gara. I can't seem to find anyone who makes or sells one - neither Haynes or Clymer? Any help much appreciated. Thanks, Max Quote Link to comment Share on other sites More sharing options...
pauldjohnson Posted December 25, 2008 Report Share Posted December 25, 2008 Hi Found this on Beta UK http://www.betatrialuk.com 1993 (FAQ) Gara 93 - Engine Oil - 800cc Fork Oil - Quantity Left 300cc Right 280cc Ignition timing - mm B.T.D.C. 2.2 - 2.3 Other - Petrol mix 70:1 Semi Synthetic Oil (70cc to 5 litres petrol) Synt 93 - Engine Oil - 800cc Fork Oil - Quantity Left 300cc Right 280cc Ignition timing - mm B.T.D.C. 2.2 - 2.3 Other - Petrol mix 70:1 Semi Synthetic Oil (70cc to 5 litres petrol) Paul. Quote Link to comment Share on other sites More sharing options...
zerogara Posted December 18, 2009 Report Share Posted December 18, 2009 http://www.trialsport.com.au/beta/Parts/Zero 90.pdf http://www.trialsport.com.au/beta/Parts/Zero 91.pdf http://www.trialsport.com.au/beta/Parts/Zero 92.pdf http://www.trialsport.com.au/beta/Parts/Zero 93.pdf http://www.carlsalter.com/aaman/Beta__Beta...ts%20manual.pdf or http://www.carlsalter.com/aaman/Beta__Beta Zero 90 parts manual.pdf http://www.carlsalter.com/aaman/Beta__Beta Zero 91 parts manual.pdf http://www.carlsalter.com/aaman/Beta__Beta Zero 92 parts manual.pdf http://www.carlsalter.com/aaman/Beta__Beta Zero 93 parts manual.pdf Those are scanned copies of parts manuals, not repair manuals, so there isn;t much on specs in there, but it helps getting stuff apart and back together. I have a 93 as well and apart from the advertised difference of fork diameter (same as 94 techno I think) the clutch has a small difference from 90-92, where this friction type inner plate is in front of the stack but not there on the 93? If anyone knows more about this please advise. Quote Link to comment Share on other sites More sharing options...
