slogger Posted December 22, 2008 Report Share Posted December 22, 2008 Have been ringing a number of dealers today (bvm, lampkins - closed, motomerlin) trying to get caliper pot/seals to do a refurb of a 95 Techno 250 rear brake. Worryingly a number of times I was told "if they are available". So what are my options ? Is their another pattern caliper that can be fitted where parts will be more readily available and if so will I need to replace the disc as well? Does anyone know suppliers of seals and caliper pots that can be provide from patterns / sizes. If so, where can I get the tech spec of the items ? Thinking worse case here as I am sure the items will be available but if not I need to be prepared! Rob Quote Link to comment Share on other sites More sharing options...
stork955 Posted December 22, 2008 Report Share Posted December 22, 2008 Measure the piston and take the seal into a car brake parts seller. You should be able to at least match it up there if genuine is not available. I have sourced pistons and seals for "unusual" applications this way in the past. Also it might pay to search the net for the caliper manufacturer - AJP have a comprehensive site in the states for example. HTH, Cheers, Stork Quote Link to comment Share on other sites More sharing options...
billboat10 Posted December 28, 2008 Report Share Posted December 28, 2008 most scooter nowdays have thesame calipers on so look at scooter brakes the techno has the same as derbi sender on it wheni went to get rev 3 brakes they dident stock them he got the book out and placed my pad by the pad in the book they was scooter ones Quote Link to comment Share on other sites More sharing options...
