Beta Techno Not Running Right
leedb
I have a Beta techno 250 1997, it will start up and tickover but not rev, sounds like its back fireing all the time. It will also kickback viollently. Been told its the stater plate. Just wondering if anyone has ever had this problem before. Thanks.
hi. i dont think you can test a stator, a stator usually breaks down when the motor is hot, wait for it to cool down and normally runs again till hot , we used to send mx stators to west country windings , did a brill job on them, have you tried cdi and coil although symptoms of a kickback are not normally related to them, hope this helps anyway. cheers
If youve got a kill switch on the bike disconnect it then see if theres a difference, is the earth wire connected well and have you checked for any shorts in the system? best way to check is to run the bike in total darkness as they will easily be spotted if a wires exposed. Has the bike ever run ok? if so what have you done to it since if anything. Pretty sure a dodgy CDI will not even let the bike start
Edited by The Addict
Do a search on this forum for techno posts, just looked on Lampkin site and no info there on jets etc. Bike will still have compression if nipped up, if jets are clean and correct size as well as float height might be worth having a look at the piston and barrel
had the same prob turned out to be stator bike would run but only if dident turn throttel also cdi coil pack from jk hirst bout 19 quid u can test the stator go to motoplat web site ittells u there or ring him he tell you what reading you should get think its somat like 450 anthing less its gone
