How Are The Evos?
sir dabs alot
I tried one last week, a bigger engine one - and in comparison with the old 270...
Engine seemed much smoother, especially at the bottom end.
Steering was even more extreme with even more lock.
Back suspension seemed more compliant.
(I should also say the back brake had sheared off)
...So if you are a Beta fan I can't see what's not to like.
A friend of mine got his....here is his early impressions.
Looks better in person. I'm not worried about damage to the radiator filler, exhaust or electronics.
Engine is substantially stronger (290 cc) and much quicker down low compared to my 270 Rev3.
Within 1.5 hours on the bike my rollups, zaps and splatters were better due to the quicker, more powerful engine.
The gearbox shifting is substantially improved, i.e., easy click gear to gear including finding neutral.
The throttle pull is substantially easier than the Mikuni that should reduce forearm fatigue.
Beta has simplified working on the bike. Fewer bolts, easier access.
Same high quality compoments...right down to the nuts and bolts.
Suspension is much quicker and the whole bike is springier. Will help with complex techniques like flip turns and zaps.
Adapting to the bike is easy compared to adapting to a Rev3.
Vast majority of the bike has new/revised/improved parts.
Skidpan is thicker/stronger and a welcomed improvement.
Front fender has an integrated plastic fork brace. I believe the rear fender can be zip-tied on to lesson the probability of breakage....but I still need to look closer to be sure.
Very happy I bought it.
