rockabilly13 Posted January 8, 2009 Report Share Posted January 8, 2009 Do you need a flywheel removal tool to remove the flywheel on a 02 rev3? I bought a used bike and it wasn't dried out properly after getting water in the cover and my flywheel is rusted. I was wanting to take it off and repaint it to stop further rust. Quote Link to comment Share on other sites More sharing options...
yamahaty250xox Posted January 8, 2009 Report Share Posted January 8, 2009 (edited) This is what you need. click screw this into your flywheel and use an impact wrench if possible to pop the flywheel off. if you dont have an impact wrench then you may need a flywheel holding tool. max Edited January 8, 2009 by yamahaty250xox Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 8, 2009 Report Share Posted January 8, 2009 This is what you need.click screw this into your flywheel and use an impact wrench if possible to pop the flywheel off. if you dont have an impact wrench then you may need a flywheel holding tool. max You should be ok with a BIG adjustable wrench on the bit screwed into the flywheel, to hold it steady, and another onto the bolt to effectivle tighten against each other. Quote Link to comment Share on other sites More sharing options...
