bikespace Posted October 9, 2004 Report Share Posted October 9, 2004 I've been thinking of buying Ryan Young's Tyre Beader but it never seems so important until you have to turn or change a tyre again. I put a new one on this morning in about 7 or 8 minutes, then it took me nearly an hour to get it back in the bead. Eventually managed it with a ratchet strap and a high power airline when I gave up on trying at home. I'm sure Michelin are making their tyres with a larger diameter these days. I didn't even use a lever to get it back on today, it went on by hand. Seems strange that on a road bike (where you've got nice painted alloys) the tyres can be a real b1tch to get on, but trials bikes (which could stand a bit more aggro) slip on no problem leaving a big gap to try and fill I used to be great at punctures when we had tubes, in a couple of minutes, now it's a full weekend job to get the bloody tyre back on Last time I tried it, the ratchet strap method didn't work and I managed it using a kids inner tube to fill the gap, then ruin the tube ripping it out of the bead. Would be cheaper in the long run to get one of these tyre beaders if they are any good. Has anybody used one??????? Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted October 9, 2004 Report Share Posted October 9, 2004 The inner tube works, but, like you said, it can rip. Some soapy water works well, but if it's too slippery, the tube pops out before it does the job. Anyway...Ryan's tire beader works very well. It too can rip, so keep it lubed. Keep a bicycle tube around in case you need to seal the other side too...as with a new tire. For new tires, keep an 18" tube around so you can put it in the tire and inflate it and let it sit for a couple days before installing the tire. This will spread the bead and help it to seat more easily. Quote Link to comment Share on other sites More sharing options...
marky g Posted October 9, 2004 Report Share Posted October 9, 2004 (edited) Hinton you fanny you IT guys are just not used to a bit of grafting are you?, too scared you might break a nail Come see me, I'll give you a few tips on tyre changing Clive on Sunday??? Edited October 9, 2004 by Marky G Quote Link to comment Share on other sites More sharing options...
bikespace Posted October 9, 2004 Author Report Share Posted October 9, 2004 Shouldn't think you go through many tyres with only a hairdrier moter to take the edge of 'em. It's probably the front edge from bump starting it eh? I thought you just bought a new bike once the tyre was rounded? Yep - Clive tomorrow - I'll be slashing the tyres on your pimp mobile so bring your tyre levers dear. Quote Link to comment Share on other sites More sharing options...
boofont Posted October 9, 2004 Report Share Posted October 9, 2004 Go on, have a punch up! The Michelins are a nightmare, I always put a tube in for at least a few days before fitting to spread the beads. Never tried using one of the little gas cartriges, anyone know if they will work? Quote Link to comment Share on other sites More sharing options...
g4321 Posted October 9, 2004 Report Share Posted October 9, 2004 Mark Would a gas cartridge have sufficient pressure or volume to force a tyre onto the bead? I have seen someone put some lighter fluid in a tyre then light it - this seated the tyre with a bang - I wouldnt like to try that though! Quote Link to comment Share on other sites More sharing options...
bikespace Posted October 9, 2004 Author Report Share Posted October 9, 2004 boofont said: Never tried using one of the little gas cartriges, anyone know if they will work? Cyanide you mean. I've considered it a few times after an hour of punching the Michelin in vain. Lighter fuel?? I'd never have thought of causing a small explosion to get the tyre on the rim, but would be good to watch.....from a distance Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted October 9, 2004 Report Share Posted October 9, 2004 Shame that I didn't know you needed a beader before my last trip to spain. euros 14. It really is the bit of kit every workshop should have, a pal and me got a tyre back on at a trial with a footpump and beeder. Quote Link to comment Share on other sites More sharing options...
bikespace Posted October 9, 2004 Author Report Share Posted October 9, 2004 That'll do for me! I thought they would probably be good, as the inner tube is nearly there. I'll have a bit of a look around, as they do seem a bit steep for a bit of rubber especially once they add shipping. Cheers Dabster et al Quote Link to comment Share on other sites More sharing options...
boofont Posted October 9, 2004 Report Share Posted October 9, 2004 You off back to Spain in the near future Dabster? Sounds like you could mack a bit of money here! Quote Link to comment Share on other sites More sharing options...
marky g Posted October 9, 2004 Report Share Posted October 9, 2004 g4321 said: MarkWould a gas cartridge have sufficient pressure or volume to force a tyre onto the bead? I have seen someone put some lighter fluid in a tyre then light it - this seated the tyre with a bang - I wouldnt like to try that though! Saw it on TV, I think it was Iceland where they have really wide tyres for Snow work, run very low pressure = they come off the rim quite often. The guy sprayed lighter fluid inside the tyre, he then struck a match and bingo!! tyre back on rim...pretty cool to watch The gas cartridge works ok for MTB, never tried it on a M/C tyre though. mark Quote Link to comment Share on other sites More sharing options...
bikespace Posted October 9, 2004 Author Report Share Posted October 9, 2004 Next time your tyre comes off we'll try it Mark. I'll spray it in, you light it while I stand back Teamwork Quote Link to comment Share on other sites More sharing options...
g4321 Posted October 10, 2004 Report Share Posted October 10, 2004 As for the lighter fluid - glad to hear I was not halucinating when I remembered seeing that at a trial in the Inverness area a few years ago. Yes it did make a bang and was effective. Mind you i wouldnt like to try it close to a bike! Quote Link to comment Share on other sites More sharing options...
trialscot Posted October 10, 2004 Report Share Posted October 10, 2004 You'll get a "tyre beader" ( they call them mousses sometimes) from any of the dealers in GB. Only snag is they cost nearly 25 quid but <i>with careful handling and some soapy water</i> they'll last forever and it's a breeze to seat a bead. Quote Link to comment Share on other sites More sharing options...
bikespace Posted October 10, 2004 Author Report Share Posted October 10, 2004 Are they exactly the same as a mousse then??? If they are I can get hold of second hand ones, but they're steeper than Quote Link to comment Share on other sites More sharing options...
