rayneedham Posted January 10, 2009 Report Share Posted January 10, 2009 Hello I recently bought a 2002/3 Rev50 for my Grandson, the question I have is regarding the cooling fan? The fan seems to run almost constantly, I've removed the temperature sensor from the block and it seems to be ok, I also put a meter across this and even at low ambient temperatures (3oC) I got a constant voltage across this. Does anyone know if this is a normally open or closed circuit, should the fan be running constantly even ehrn the engine is cold? Thanks Ray Quote Link to comment Share on other sites More sharing options...
fellonmelug Posted January 11, 2009 Report Share Posted January 11, 2009 Try a resistance check across the sensor at 30 degrees C it should be open circuit or infinity ohms , if not you should replace the sensor Quote Link to comment Share on other sites More sharing options...
ashbabble Posted January 11, 2009 Report Share Posted January 11, 2009 My son's fan was running all the time yesterday and when I checked, the rad was cold - soooooo - it had no coolant in. Sounds silly but have you checked? Cheers Quote Link to comment Share on other sites More sharing options...
