milfy Posted January 11, 2009 Report Share Posted January 11, 2009 first trial on monty and snapped off the rear brake lever so my question is is this a common failure or just a one off breakage ? i have seen a after market lever which is twice the price of the normal montesa part so do i replace with stock or after market lever http://handdracing.com/page3.htm Quote Link to comment Share on other sites More sharing options...
4ourtea Posted January 11, 2009 Report Share Posted January 11, 2009 This problem is not unusual for the Mont as the rear brake lever sticks out a heck of a long way compared to those on other bikes. When you do catch it, it usually bends or breaks. When I broke my second one in nearly as many weeks, I did a simple mod to it rather than lash another wad on a lever again: I shortened the arm on the broken bit with the tip on it(i.e the bit that your foot goes onto) and then i re-welded this onto the bit that mounts onto the frame. the key thing was to shorten it sufficiently enough for it (once welded back on) to be tucked in behind the casing. This protected it from snagging on every rock that brushes past the right hand case, without compromising your ability to get a foot on the brake. If you want to go one step further still, I also chopped off some of the serrated triangle so that it was even more tucked away. It may sound drastic and feel awkward at first (different target to hit) but you soon get used to it. If you still don't like it after a couple of weeks at least you've tried to save some money and you've not lost anything. Next and last resort - buy the H and R racing piece!! Quote Link to comment Share on other sites More sharing options...
milfy Posted January 11, 2009 Author Report Share Posted January 11, 2009 only good thing it snapped on the last section so didnt spoil the day has i will be keeping it for a good few months i may buy the H+D one its the price of 2 so makes sense in the long run thanks for that just thought it was me, other wise very happy with bike Quote Link to comment Share on other sites More sharing options...
perce Posted January 12, 2009 Report Share Posted January 12, 2009 the H&D brake pedal is a top notch piece of work & is far better than a standard pedal. Quote Link to comment Share on other sites More sharing options...
jimmyl Posted January 12, 2009 Report Share Posted January 12, 2009 The pedal normal snaps across the bolt hole for the folding end. This normaly leaves a slot at the end of the pedal. By fileing a piece of alloy to fit into this slot and of a suitable size to get your foot on this can be attached by drilling and tapping from the reverse of the pedal. Worth doing as a spare if nothing else. Hour or so in the garage and the jobs a good one Quote Link to comment Share on other sites More sharing options...
milfy Posted January 12, 2009 Author Report Share Posted January 12, 2009 The pedal normal snaps across the bolt hole for the folding end. This normaly leaves a slot at the end of the pedal. By fileing a piece of alloy to fit into this slot and of a suitable size to get your foot on this can be attached by drilling and tapping from the reverse of the pedal. Worth doing as a spare if nothing else.Hour or so in the garage and the jobs a good one would love to but its in the merthyr sections some where didnt see come off only notice when i was going down the hill to the next one ordered H+D so will be on for next week end in neath Quote Link to comment Share on other sites More sharing options...
griffinjay Posted April 26, 2009 Report Share Posted April 26, 2009 first trial on monty and snapped off the rear brake lever so my question is is this a common failure or just a one off breakage ?i have seen a after market lever which is twice the price of the normal montesa part so do i replace with stock or after market lever http://handdracing.com/page3.htm I just snapped mine off yesterday. The Hand Racing website appears to be unavailable/down, but I see this Moto Merlin rear brake pedal available on eBay: Rear brake pedal to suit all 315R and 4RT models from 98-09. This pedal comes complete with pivot bearing and seals, cylinder pushrod & folding tip. Anyone hear good or bad about it? Quote Link to comment Share on other sites More sharing options...
marky boy Posted April 26, 2009 Report Share Posted April 26, 2009 (edited) There was a temporary issue as the server was doing maintainance, but is all back online Edited April 27, 2009 by marky boy Quote Link to comment Share on other sites More sharing options...
fantic303 Posted April 27, 2009 Report Share Posted April 27, 2009 When I broke my second one in nearly as many weeks, I did a simple mod to it rather than lash another wad on a lever again: I shortened the arm on the broken bit with the tip on it(i.e the bit that your foot goes onto) and then i re-welded this onto the bit that mounts onto the frame. the key thing was to shorten it sufficiently enough for it (once welded back on) to be tucked in behind the casing. This protected it from snagging on every rock that brushes past the right hand case, without compromising your ability to get a foot on the brake. If you want to go one step further still, I also chopped off some of the serrated triangle so that it was even more tucked away. Do you have a picture of your modification ? Quote Link to comment Share on other sites More sharing options...
