copemech Posted December 15, 2003 Report Share Posted December 15, 2003 Ok, for all those wondering about retrofitting the earlier bikes with the new Delta link, I decided to try one as Ryan(RYP) had one available and said it should work on all earlier models. I had been one of the first to ride the new 04 model that David Chaves had recieved and really could not tell a lot of difference initially, but the bike was still new and somewhat stiff with new springs not broken in yet, but I decided to try one on my 03 bike anyway with Ryan's blessing (and 70 bucks)! Apparently there is indeed not much of a change in the shock 03-04 and probably no change in the spring however I do not have the part numbers to be sure. Anyway, spending a rainy evening last week, I installed the new widget, noting the slight differences in its dimensions as compared to the original, and lubed everything as per the proper maintenance ov the dog bones. After reassembly, the first thing I had to do was to crank up the spring preload a couple of turns to decrease the static sag to just about 1/2 to 3/4in to feel correct when depressing the rear, it seemed quite plush! Then waited untill today when the ground dried enough to do a bit of a practice session in the back yard. Well, after a half hour or so of riding the logs and curbs in the back, the analogy that came to mind was like the difference in a foam pillow and a soft feather down pillow. It just felt good and very compliant if a bit soft by comparison. I may need to jack up the spring a bit more, not sure yet. Guess I will find out at the next outing! Cheers and Merry Christmas! :santawink: Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted December 15, 2003 Report Share Posted December 15, 2003 Have an 04 and would like to know if Ive got the new delta link or not.Could you dimension the old one 03 for me? milimetres if poss? Nice cheesy please? Quote Link to comment Share on other sites More sharing options...
copemech Posted December 16, 2003 Author Report Share Posted December 16, 2003 Nigel, I measured 49.5 lower side as installed,x 46.5 x 29 for the 03 link. +-.5mm Though I did not measure the new one, there was a 2mm or more difference on one side and maybe 1mm on another as held next to each other. Cheers Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted December 16, 2003 Report Share Posted December 16, 2003 Thanks very much. :santawink: Quote Link to comment Share on other sites More sharing options...
copemech Posted December 24, 2003 Author Report Share Posted December 24, 2003 As an update. I rode several hours practice over the weekend, seem to work great, really smooth and plush. Had to jack up the spring some more. :santawink: :hat: :madsanta: :santawink: :madsanta: :santawink: :hat: :madsanta: Quote Link to comment Share on other sites More sharing options...
