315r Paoli Forks
jonathan collier
Can any kind soul tell me how much and what weight oil I should be putting in paoli forks on a 98 mont?
Thanks
On a '99 with the Paoli forks it's 360ml of 5W oil each leg - Levels are 70mm for right leg, 125mm for left. The '97 and '98 have got different fork tubes (stanchions) so how much difference that makes to the oil volume I can't say but I don't reckon 360ml would be a million miles away. As far as I know the only difference in the tubes is colour/surface finish. Remember too that you can add a bit more to reduce the air gap at the top of the forks if they bottom out too easily with your static sag preload settings so the specified oil volume is only a guide.
  • 2 weeks later...
