eugheugh Posted January 15, 2009 Report Share Posted January 15, 2009 Hi all Does anyone know where I can get a schematic diagram of how to assemble a villiers 4 speed gearbox (36a) as I have wasted a huge amount of time getting it wrong-I can only select 2 gears and you have to stamp on the gearlever to get them. Quote Link to comment Share on other sites More sharing options...
geebee Posted January 15, 2009 Report Share Posted January 15, 2009 Hi For Villiers information try the following: www.isdm.co.uk/villiersinfo Geebee Quote Link to comment Share on other sites More sharing options...
isaacely Posted January 15, 2009 Report Share Posted January 15, 2009 Try this link it should lead to a diagram of the gearbox. Good luck. Alan http://www.lortim.demon.co.uk/vsih/gearbox.htm Quote Link to comment Share on other sites More sharing options...
sparks2 Posted January 16, 2009 Report Share Posted January 16, 2009 Hi I am not going to describe in detail how to assemble a Villiers box here. However the most significant tip is to assemble the box IN NEUTRAL with everthing sat on the outer cover (with the shafts pointing upwards). Then offer the main housing down onto this. With a few trial fits everything should then come together. Watch the clearance between the gears and the main housing (second gear clearance gives trouble sometimes). Hope this helps. Regards Sparks2 Quote Link to comment Share on other sites More sharing options...
eugheugh Posted January 17, 2009 Author Report Share Posted January 17, 2009 Thanks for the advise guys. Further to this - do the selector forks need to be positioned so the the 'windows' align with the holes in the selector drum ?. If this doesn't make much sense I'll take some photo's. Quote Link to comment Share on other sites More sharing options...
sparks2 Posted January 17, 2009 Report Share Posted January 17, 2009 Hi Sorry your last post makes no sense to me Regards Sparks2 Quote Link to comment Share on other sites More sharing options...
eugheugh Posted January 18, 2009 Author Report Share Posted January 18, 2009 Sorry. Does anyone know how to send Jpeg images without having my name attached to them ? Quote Link to comment Share on other sites More sharing options...
