Villiers 4s Gearbox Assembly-help!
eugheugh
Hi all
Does anyone know where I can get a schematic diagram of how to assemble a villiers 4 speed gearbox (36a) as I have wasted a huge amount of time getting it wrong-I can only select 2 gears and you have to stamp on the gearlever to get them. :wub:
Hi
I am not going to describe in detail how to assemble a Villiers box here. However the most significant tip is to assemble the box IN NEUTRAL with everthing sat on the outer cover (with the shafts pointing upwards). Then offer the main housing down onto this. With a few trial fits everything should then come together. Watch the clearance between the gears and the main housing (second gear clearance gives trouble sometimes). Hope this helps.
Regards
Sparks2
