hop blip and a jump Posted January 18, 2009 Report Share Posted January 18, 2009 (edited) I'm trying to get hold of 2 bearings 6304.c3 with plastic ball cages??? I'm struggling to find anywhere that can supply them, i can get ones with steel riveted cages, but would like to replace them like for like.. they are gearbox main bearings in my 87 garelli. Please help?? Edited January 18, 2009 by hop blip and a jump Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 18, 2009 Report Share Posted January 18, 2009 I'm trying to get hold of 2 bearings 6304.c3 with plastic ball cages???I'm struggling to find anywhere that can supply them, i can get ones with steel riveted cages, but would like to replace them like for like.. Please help?? Try http://www.bearingboys.co.uk/search.cgi Quote Link to comment Share on other sites More sharing options...
shercoman2k8 Posted January 18, 2009 Report Share Posted January 18, 2009 http://simplybearings.co.uk/shop/ Quote Link to comment Share on other sites More sharing options...
hop blip and a jump Posted January 18, 2009 Author Report Share Posted January 18, 2009 I've looked on loads of sites and can only find bearings with steel cages!?!? Quote Link to comment Share on other sites More sharing options...
lee harris Posted January 18, 2009 Report Share Posted January 18, 2009 they are the same as a 300 fantic crank if you ditch the old split type. i can get them here at about 35 euros each. Auch! PM me if help is needed lee Quote Link to comment Share on other sites More sharing options...
wayne_weedon Posted January 18, 2009 Report Share Posted January 18, 2009 (edited) I'm trying to get hold of 2 bearings 6304.c3 with plastic ball cages???I'm struggling to find anywhere that can supply them, i can get ones with steel riveted cages, but would like to replace them like for like.. they are gearbox main bearings in my 87 garelli. Please help?? Go to you local bearing factors and ask them to look them up. C3 is the radial clearance rating and will be quite important. The cages are probably phenolic (Tufnol) Though in a gearbox I'm not sure what advantage Phenolic cages will give. Wayne.... Edited January 18, 2009 by wayne_weedon Quote Link to comment Share on other sites More sharing options...
copemech Posted January 19, 2009 Report Share Posted January 19, 2009 Go to you local bearing factors and ask them to look them up. C3 is the radial clearance rating and will be quite important. The cages are probably phenolic (Tufnol) Though in a gearbox I'm not sure what advantage Phenolic cages will give.Wayne.... Agreed, as the steel caged bearing from a quality manufacturer may actually be better! Quote Link to comment Share on other sites More sharing options...
craig10 Posted January 19, 2009 Report Share Posted January 19, 2009 They're maybe polyamide cages which don't like gear oil, although it does take some time for them to go brittle and break up, and you're probably using ATF or equivalent in your 'stroker. Moto Guzzi gearboxes are known for the gearbox bearing cages breaking up, the fix is to replace them with steel caged ones. There's some info here; http://www.skf.com/portal/skf/home/product...;newlink=1_0_59 Quote Link to comment Share on other sites More sharing options...
