talljohn Posted January 21, 2009 Report Share Posted January 21, 2009 I have a Tiger Cub with Fantic forks - with a serious leak. Problem is I don't know what model the forks are or what bike they came off. I have bought some new seals the same size as those already on the bike (32x42x8), but now I need to add the oil - question is how much?? For those Fantic enthusiasts who may be able to help, the details are: 32mm stanchions Drum brake left hand pull Original colour - Red Drain screw at bottom rear of each leg Hex bolt in bottom secures internals Four sided alloy screw threaded bolt secures spring Thanks, John Quote Link to comment Share on other sites More sharing options...
lee harris Posted January 21, 2009 Report Share Posted January 21, 2009 (edited) They are probably Betor which were fitted std to the 50s and 80s Trial version. Start at 170ml, 10ml if you are light enough. Edited January 21, 2009 by Lee Harris Quote Link to comment Share on other sites More sharing options...
talljohn Posted January 22, 2009 Author Report Share Posted January 22, 2009 Thanks for the advice. I did some more searching last night, and they look a lot like an early series Fantic trial 125. Quote Link to comment Share on other sites More sharing options...
spud Posted January 23, 2009 Report Share Posted January 23, 2009 They are probably Betor which were fitted std to the 50s and 80s Trial version. Start at 170ml, 10ml if you are light enough. An endless knowledge you should apply to go on Master Mind.......Are you sitting comfortably......then i'll begin......Q: How many of the 240 model has Fantic produced?.... Quote Link to comment Share on other sites More sharing options...
lee harris Posted January 24, 2009 Report Share Posted January 24, 2009 I know that one...24000 in trial and 7 day version...Agrati said so anyways... L Quote Link to comment Share on other sites More sharing options...
spud Posted January 24, 2009 Report Share Posted January 24, 2009 I know that one...24000 in trial and 7 day version...Agrati said so anyways...L correct you still doing that 3 day event? Quote Link to comment Share on other sites More sharing options...
lee harris Posted January 24, 2009 Report Share Posted January 24, 2009 as long as i have a hole in bottom......or money, then yes i will call, tomorrow nite???? Quote Link to comment Share on other sites More sharing options...
spud Posted January 24, 2009 Report Share Posted January 24, 2009 as long as i have a hole in bottom......or money, then yesi will call, tomorrow nite???? 'a hole in your bottom'......thats a bit below the mark ........i'm sure you meant to say eyes in your head sounds a bit better. np, spk soon Quote Link to comment Share on other sites More sharing options...
