Gasgas Misfire
betarob
hey there,
I have an 09 gasgas 125 and recently it seems to be misfiring with no consistency. Most of time it will run absolutely great but then occasionally it will misfire through the mid-high rev range. It has had a new plug, the carb is cleaned regularly, and the mixture is set up correctly.
What could be the problem?
Thanks
rob
Check the ground wire that runs to the CDI box. It can pull out of the connector into the CDI box giving intermittent contact. You can't tell by looking, pull the plug and check all that all the contacts are even. Be careful when you reinstall the plug the grond wire is just long enough to reach. I have seen this happen to one 08 125 and to me on an 07 300 after removing the light harness :thumbup:
