betarob Posted January 21, 2009 Report Share Posted January 21, 2009 hey there, I have an 09 gasgas 125 and recently it seems to be misfiring with no consistency. Most of time it will run absolutely great but then occasionally it will misfire through the mid-high rev range. It has had a new plug, the carb is cleaned regularly, and the mixture is set up correctly. What could be the problem? Thanks rob Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 21, 2009 Report Share Posted January 21, 2009 I would empty the tank and carb and try new fuel. Quote Link to comment Share on other sites More sharing options...
pandelboy Posted January 21, 2009 Report Share Posted January 21, 2009 check earth wiring from cdi and if thats all ok try disconnecting the cut out switch as it could be tracking out to earth, could also be a dodgy plug cap, try one thing at a time and test the bike. Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 21, 2009 Report Share Posted January 21, 2009 try one thing at a time and test the bike. Good advise, always remember " Whats the last thing I did" useful for identifying problems. Quote Link to comment Share on other sites More sharing options...
greg Posted January 21, 2009 Report Share Posted January 21, 2009 take it back to the dealers. Quote Link to comment Share on other sites More sharing options...
no1 Posted January 21, 2009 Report Share Posted January 21, 2009 Its the plug cap Quote Link to comment Share on other sites More sharing options...
spinner Posted January 22, 2009 Report Share Posted January 22, 2009 Check the ground wire that runs to the CDI box. It can pull out of the connector into the CDI box giving intermittent contact. You can't tell by looking, pull the plug and check all that all the contacts are even. Be careful when you reinstall the plug the grond wire is just long enough to reach. I have seen this happen to one 08 125 and to me on an 07 300 after removing the light harness Quote Link to comment Share on other sites More sharing options...
