peteostatic Posted January 22, 2009 Report Share Posted January 22, 2009 Hi all, New on here, would appreciate some help with a problem on my 06 250 Rev 3. When travelling between sections, in higher gears, when the engine is under load(up hills) it has a tendancy to bog down, almost as if the ignition has cut out. Dropping a gear and getting the revs back up cures it, or slipping the clutch. Not normally a problem but it happened on a hill climb section recently, which wasn't very helpful! Recent stator plate fit and new cylinder/piston kit too. Thought it might be fuel starvation, I would assume the jetting is standard. Any one experience similar? Quote Link to comment Share on other sites More sharing options...
nicbrrghs Posted January 22, 2009 Report Share Posted January 22, 2009 Hi, Have a search on here and do the carb mods( Float level, T piece hoses etc) these make a huge difference also the float bowl extension, brilliant bit of kit. Quote Link to comment Share on other sites More sharing options...
peteostatic Posted January 22, 2009 Author Report Share Posted January 22, 2009 Cheers nic, have seen those and will have another look. Thanks Quote Link to comment Share on other sites More sharing options...
