2001 Txt280 Gear Oil?
tomlinson_d
hi there is there anyone who could tell me how much gear oil i should put in my txt 280 ive drained about 500ml out of it and wasnt sure if there should be more or less.
thanks alot if anyone can help.
You might think about running about 650-700cc's of a light-weight trans fluid in cooler weather, say 5W-30 or Dexron ATF in the "Edition" type engine.
Jon
You can check if you loaded the correct amount by looking in the little round window on the right side of the tranny. It should be about half way up the window.
In my '02 Edition, I've been using the cheapest ATF I can find at Walmart, and it works just fine. I change it 2 or 3 times per year, and clean off the drain plug magnet while I'm at it.
Dave
