neilnh Posted January 25, 2009 Report Share Posted January 25, 2009 I have just changed to a 12 tooth front and 44 tooth rear sprocket but am now finding the bike is too fast in first gear a little blip on the gas and its away can i cure the problem by fitting a ten tooth front sprocket or would i have to change the rear as well. I was on an 11 tooth front and 41 rear Quote Link to comment Share on other sites More sharing options...
zerogara Posted February 23, 2009 Report Share Posted February 23, 2009 I have just changed to a 12 tooth front and 44 tooth rear sprocket but am now finding the bike is too fast in first gear a little blip on the gas and its away can i cure the problem by fitting a ten tooth front sprocket or would i have to change the rear as well. I was on an 11 tooth front and 41 rear 41/11=1:3.727 44/12=1:3.6667 44/11=4 44/10=4.4 so that would be a big leap the other way, a ten would be too big of a difference i think, slow you down too much where 2nd would be just as first is now. you can change the 12 to an 11 and take up a little slack at the chain. Quote Link to comment Share on other sites More sharing options...
