eddie_lejeune Posted March 1, 2009 Report Share Posted March 1, 2009 (edited) rev 3 wheel wont fit an evo, is there a kit now available then, i made my own mods and broke the hib so id like to see a picture of what someone else hase come up with Edited March 1, 2009 by Eddie_Lejeune Quote Link to comment Share on other sites More sharing options...
curly Posted March 1, 2009 Report Share Posted March 1, 2009 good news. What kit? Andy Metcalf Motorcycles (Tel 01642 475600) obtained mine. As I said earlier it comprises of new disc, washers to go behind, and 2 new spacers (which are the same size as the sprocket side). The washers supplied were too thick and the bolts need replacing with slightly longer ones to get more thread, but small points when it saves buying a new wheel. I can't really understand the problem since there is only a slight difference between last years spec and the new evo. If I did another one I would just order a disc and an extra sprocket side spacer and dig up the rest of the bits in the garage. Our wheel has now done 3 weeks practice and yesterdays Brit Championship practice day without any problems. Quote Link to comment Share on other sites More sharing options...
eddie_lejeune Posted March 1, 2009 Report Share Posted March 1, 2009 could you possibly get a picture of how its done? is the spacer in the disc side then? Quote Link to comment Share on other sites More sharing options...
curly Posted March 1, 2009 Report Share Posted March 1, 2009 could you possibly get a picture of how its done? is the spacer in the disc side then? All you do Eddie is: remove existing disc (ours is a 07 Beta wheel) and replace with Evo disc with washers behind. Make sure your bolts are long enough for threads. Fit a spacer the same as the sprocket side. Check disc fits exactly in centre of brake. If not, change washers behind disc to suit. Locktite on. Job done! Quote Link to comment Share on other sites More sharing options...
eddie_lejeune Posted March 2, 2009 Report Share Posted March 2, 2009 thanks curly, why do you need an evo disc? the rev 3 disc will fit in so is it not just a matter of spacing it out then? Quote Link to comment Share on other sites More sharing options...
nzralphy Posted March 3, 2009 Report Share Posted March 3, 2009 Becuase the disk is 150mm dia rather than the 165mm fitted to the rev3 Quote Link to comment Share on other sites More sharing options...
butt mooar Posted March 3, 2009 Report Share Posted March 3, 2009 is the sprocket side spacer the thinner one of the two? Quote Link to comment Share on other sites More sharing options...
curly Posted March 3, 2009 Report Share Posted March 3, 2009 is the sprocket side spacer the thinner one of the two? Thicker..I think! Will check later. Quote Link to comment Share on other sites More sharing options...
eddie_lejeune Posted March 3, 2009 Report Share Posted March 3, 2009 curly get us a pic of it please mate!! Quote Link to comment Share on other sites More sharing options...
curly Posted March 4, 2009 Report Share Posted March 4, 2009 curly get us a pic of it please mate!! Bloody hell! OK, but off to SDMC Meeting tonight, will try and upload it tomoz. Quote Link to comment Share on other sites More sharing options...
eddie_lejeune Posted March 4, 2009 Report Share Posted March 4, 2009 thanks!! Quote Link to comment Share on other sites More sharing options...
butt mooar Posted March 5, 2009 Report Share Posted March 5, 2009 Cheers curly... Quote Link to comment Share on other sites More sharing options...
curly Posted March 5, 2009 Report Share Posted March 5, 2009 Ok, here's the pics. http://picasaweb.google.com/lownorthcamp/B...nversionForEVo# Quote Link to comment Share on other sites More sharing options...
eddie_lejeune Posted March 5, 2009 Report Share Posted March 5, 2009 thanks curly Quote Link to comment Share on other sites More sharing options...
