Gasgas Rear Brake Shim
hrcmonty
Has anybody managed to purchase or make just the little shim the fits inside the rear brake pedal?
It's the little shim that sits between the actual pedal and the bolt.
For some reason gas gas apparently don't sell this sepratly. So when it wears and the pedal starts to move all over the joint, you need to buy a new pedal and bolt.
Use a refreshing beverage can of your choice and a sharp pair of scissors, get a piece of tube the same size as the bolt and sharpen the end. Use it as a punch to cut the inside hole, then cut the outer diameter with the scissors. You can make as many as you like to take up the slack
