hamster Posted January 28, 2009 Report Share Posted January 28, 2009 hi all has any one got the standard settings for a 2006 gasgas 300 carb ie fuel screw position,pilot and needle sizes Quote Link to comment Share on other sites More sharing options...
jse Posted January 28, 2009 Report Share Posted January 28, 2009 hi all has any one got the standard settings for a 2006 gasgas 300 carb ie fuel screw position,pilot and needle sizes Should be in this neighborhood: TXT280-300 PRO WITH PHBL26 (26mm) SEA LEVEL TO 3,000 FEET MAIN: 118 (115 OK, NOTHING SMALLER!) PILOT: 36 (38 OK) NEEDLE: D36 (3rd, or 2nd CLIP POSITION DOWN FROM TOP) FUEL SCREW: 3.5 TURNS OUT FLOAT HEIGHT: ARMS IN LEVEL PLANE WITH FLOAT BOWL BASE (PARALLEL) Jon Quote Link to comment Share on other sites More sharing options...
hamster Posted January 29, 2009 Author Report Share Posted January 29, 2009 thank you will check them today Quote Link to comment Share on other sites More sharing options...
txt_280 Posted January 31, 2009 Report Share Posted January 31, 2009 Should be in this neighborhood:TXT280-300 PRO WITH PHBL26 (26mm) SEA LEVEL TO 3,000 FEET MAIN: 118 (115 OK, NOTHING SMALLER!) PILOT: 36 (38 OK) NEEDLE: D36 (3rd, or 2nd CLIP POSITION DOWN FROM TOP) FUEL SCREW: 3.5 TURNS OUT FLOAT HEIGHT: ARMS IN LEVEL PLANE WITH FLOAT BOWL BASE (PARALLEL) Jon Jon do you have similar for a 2001 txt 280??? cheers Quote Link to comment Share on other sites More sharing options...
jse Posted January 31, 2009 Report Share Posted January 31, 2009 Jondo you have similar for a 2001 txt 280??? cheers This should help: 1998/99 TX270 2000/01/02/03 TXT280, TXT280, TXT321, TXT280 Quote Link to comment Share on other sites More sharing options...
