1sherco1 Posted January 28, 2009 Report Share Posted January 28, 2009 i just messin about after a trial on a jump and i kept bottom in out seems fine in trials thow any sugestions?? cheers josh Quote Link to comment Share on other sites More sharing options...
copemech Posted January 30, 2009 Report Share Posted January 30, 2009 i just messin about after a trial on a jump and i kept bottom in out seems fine in trials thow any sugestions??cheers josh Just one, try to insure your spring has not sagged too much. A drop of the rear under only the weight of the bike of around 20-30mm would be ok. If yours drops more than this when picking up and letting go the rear, you need to twist the spring up a bit on the shocker. Quote Link to comment Share on other sites More sharing options...
