sherco25016 Posted January 30, 2009 Report Share Posted January 30, 2009 Is it normal when i start my sherco and leave it to warm up for 5 mins, i pull the clutch in and knock it into gear the bike will set off with the clutch fully in and drag me for a little bit then it just stops and it fine. i had this same problem on a montesa 314 i got told it was just a trials bike thing. Josh Quote Link to comment Share on other sites More sharing options...
theshercorider Posted January 30, 2009 Report Share Posted January 30, 2009 Mine does the same and usually happens when its been stood for a while. First time it happened to me I ended up hitting a car and it costing over Quote Link to comment Share on other sites More sharing options...
sherco25016 Posted January 30, 2009 Author Report Share Posted January 30, 2009 my dad told me to pump the clutch, am glad i didnt hit a car thanks for the help josh Quote Link to comment Share on other sites More sharing options...
b40rt Posted January 30, 2009 Report Share Posted January 30, 2009 It is a trial bike thing that happens to many, but not all, bikes. Start and warm engine, roll bike forward and put into gear, ride around with clutch in, usually works. Quote Link to comment Share on other sites More sharing options...
sdc Posted January 30, 2009 Report Share Posted January 30, 2009 Change immediately into 3rd and it'll clear. Quote Link to comment Share on other sites More sharing options...
tombo46 Posted January 30, 2009 Report Share Posted January 30, 2009 dragging the rear brake can free it up too (at least it did on the beta). Tom Quote Link to comment Share on other sites More sharing options...
fantic156 Posted January 30, 2009 Report Share Posted January 30, 2009 Try the ELF HTX 740 expensive but has always cured a sticking/dragging clutch on all the bikes I Quote Link to comment Share on other sites More sharing options...
1oldbanjo Posted January 30, 2009 Report Share Posted January 30, 2009 On my Sherco I was starting to have a clutch release problem. At first I would just start the bike, roll it forward and put it into first gear and then pull in the clutch and apply some rear brake - and it would work fine the rest of the day. As the summer went on it took longer for me to get it to release. A few weeks ago I had the bike in 3rd, 4th and 5th and could not get the clutch to release after the bike sat for about 3 weeks (We are officially into winter and the snow was just too deep to ride). While the weather was bad I took the clutch cover off and took the clutch apart. I cleaned the metal and fiber discs with mineral spirits and and then lightly scuffed the metal discs with some fine emery cloth until the shine was gone. I laid the emery cloth on a sheet of glass and then slid the fiber discs across the emery cloth until the gloss was gone from the fiber. I then cleaned them again and dried them off. I put it all back together and added new fluid. The clutch now works perfectly and releases very easily. I think I may have been going too long between oil changes. Quote Link to comment Share on other sites More sharing options...
joostio Posted January 31, 2009 Report Share Posted January 31, 2009 my 06 2.9 does the same thing. Now I learned how to deal with it. 1 start bike in neuteral 2 pull in clutch, rev engine a bit, do this for a good 30 seconds, clutch in, out, in out ect.. 3 problem solved Quote Link to comment Share on other sites More sharing options...
copemech Posted January 31, 2009 Report Share Posted January 31, 2009 (edited) Change immediately into 3rd and it'll clear. No it will not! It is a normal condition, and must be made aware, or you young dumplings might continue to run into things! Even a 125 is hard to stop! I will put out some pointers for you punters! From cold and sat, place it in 4th ot 5th gear, pull the clutch, and rock the bike untill it rolls smoothly! Using the same method, you may use the kicker(slowly) while holding the bike back. A good doublecheck! Fresh oil in the gearbox may help, do not trust it! Do not trust ANYTHING, and always be sure you are pointed properly BEFORE placing into gear! Use your head and do not rush your procedure! The colder it is, well go figure! You do not really to rev the motor to much off cold anyway, you may stick a piston! So be smart and safe! Edited January 31, 2009 by copemech Quote Link to comment Share on other sites More sharing options...
clav3 Posted February 1, 2009 Report Share Posted February 1, 2009 I,ve used Shell Advance 15W-50 for a few months to help stop clutch grab and shudder when slipping the clutch alot in tight shaily sections and since this change have never had the clutch stick when starting. Also never had the clutch slip in high revs when fully engaged. Quote Link to comment Share on other sites More sharing options...
