Front Wheel Removal
orange250
One end of the spindle screws into the other, leave the pinch bolts tight on the right side and undo the pinch bolts and spindle from the disc side. THen undo the pinch bolts on the right and tap the spindle through, you need a socket the size of the OD of the spindle to avoid damaging the threads
Edited by Baldilocks
Tighten the pinch bolts again on the disc side and undo and remove the allen socket headed retainer. Undo the pinch bolts and push the spindle through from the brake side using your fingers until you have enough to grab hold of the spindle and pull from the other end. That's assuming it was nice and greasy when it was put in :D
All done cheers.
I also bled the brakes today, but when i went to bleed the clutch the nipple snapped off! Does this come with a new cable or can you buy just thenipple and what goes into caseing?
Thanks again.
Ask your dealer for a banjo bolt #MO106000, which has the bleeder nipple on it.
Jon
