4rt, Can Stator Be The Only Reason For No Spark
mostar
I had no spark during a trial a couple of years ago and checked most things before finding that the throttle cable had been pulled up in the rubber shroud when I dropped it. This tells the EFI that the throttle is too far open for safe starting and shuts off both ignition and fuel injection. Pushed cable back in and started first kick. I was initially baffled because I had no spark but even after trying to run the bike to start the plug was coming out dry.
You also don't mention checking the tilt switch, this is also a possibility for no spark.
Good luck.
Hi
Yer checked the cap and cable and all gud. Thanks for the help any way guys.
I measured the resistance between the regulator rectifier and the alternator as it says to do in the manual. and it was wrong and the manual said if both measure wrong the step is to replace the stator assembly.
So that's where I am at and I hope Im right as big money if not.
Cheers
Hi
Just letting you know bike now has spark. it turned out to be one power wire that was broken. but not right though and when I did the test it show up ok . but when I went to try and get spark or start it was not touching together.
So after many hours it now is all gud.
Stator was OK as well.
Cheers for the help
