vasey15 Posted February 1, 2009 Report Share Posted February 1, 2009 Rode a really muddy trial today, on the 10th section of the 1st lap, the revs started to increase rapidly. The cable wasn't nipped and it sounds like the slider is re-seating. any suggestions? Cheers. Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 1, 2009 Report Share Posted February 1, 2009 Running lean, blocked jet ? Quote Link to comment Share on other sites More sharing options...
rlracer Posted February 1, 2009 Report Share Posted February 1, 2009 If the cable isn't pulled out and if the slide is hitting bottom, I'd look for an air leak. Quote Link to comment Share on other sites More sharing options...
robin m. s/c Posted February 1, 2009 Report Share Posted February 1, 2009 Mine did that a couple of times. Found it was the fact I didn't have a normal breather pipe on but one of those REP one way things. As bike got hot & caused petrol in tank to expand it was forcing fuel into carb! Use standard breather pipe & now OK Quote Link to comment Share on other sites More sharing options...
pommietrialsnz Posted February 1, 2009 Report Share Posted February 1, 2009 Has the vacuum tube come off? Quote Link to comment Share on other sites More sharing options...
davh Posted February 2, 2009 Report Share Posted February 2, 2009 Sounds terrible Mate!!!! You should have bought a Montesa like i told you!!! It could be because the beast is pump your forearms up that much you didn't realise you were pulling the throttle on full tittle!!!! Sound advice mate clean the carb, get a one way valve for the tank!! Failing that sell it and buy a 500 MAICO!!! Prob got less power than that monster!! Quote Link to comment Share on other sites More sharing options...
