mudman Posted February 4, 2009 Report Share Posted February 4, 2009 Hi, I have a sherco 2t 2008 that is sometimes hard to get into 3rd gear only(all other gears are ok) if you use a bit more force it does go in. As it is a intermitant problem should i see if it improves or should i be stripping to find problem now It is a 2008 bike but has had very little use Any help would be much appreciated Andrew Quote Link to comment Share on other sites More sharing options...
rcgods Posted February 4, 2009 Report Share Posted February 4, 2009 Change the gear oil and look dip a magnet into the old oil to check for metal fragments. Quote Link to comment Share on other sites More sharing options...
mudman Posted February 4, 2009 Author Report Share Posted February 4, 2009 rcgods, changed the gear oil after i rode last sunday and oil was free of any metal bits Quote Link to comment Share on other sites More sharing options...
copemech Posted February 4, 2009 Report Share Posted February 4, 2009 Will likely smooth out with use. Quote Link to comment Share on other sites More sharing options...
borus Posted February 4, 2009 Report Share Posted February 4, 2009 i found mine stiff at first, it gets better with use cheers Quote Link to comment Share on other sites More sharing options...
mudman Posted February 4, 2009 Author Report Share Posted February 4, 2009 thanks for the replys will give it a few more trials and see if it improves Quote Link to comment Share on other sites More sharing options...
