mudman Posted February 4, 2009 Report Share Posted February 4, 2009 Hi, I have taken the rear brake pedal off of my sherco 2t 2008 because the tip was bent and i needed to straighten it. On fitting the pedal when i tighten the retaining bolt the pedal locks up until i back off bolt, have i lost a washer or something as surely this bolt should be tight and still allow free movement of pedal? regards Andrew Quote Link to comment Share on other sites More sharing options...
husky Posted February 4, 2009 Report Share Posted February 4, 2009 Try a new bolt,possibly the bolt is slightly bent from the impact Quote Link to comment Share on other sites More sharing options...
copemech Posted February 4, 2009 Report Share Posted February 4, 2009 The bolt should tighten against the flange end of the bushing. The bearing(and pedal) should rotate freely on the bushing. Quote Link to comment Share on other sites More sharing options...
mudman Posted February 4, 2009 Author Report Share Posted February 4, 2009 Copemech, will take off and make sure bush is free to rotate in top hat bush thanks for the help Quote Link to comment Share on other sites More sharing options...
