How Do You Remove A Clutch Basket On A Cota 200
russelld
Once you get the nut off the clutch plate assy pulls off complete and you should be able to withdraw the clutch basket but it is tight on the shaft (look out for the 3 rollers dropping out as you remove). The kickstart problem is normally a worn kick start shaft bush in the casing (In-Motion sell them), a loose gear shaft bearing in the casing that the "double gear" fits on (I use shim steel and locktite to re-secure) or the double gear itself is worn. I have one as new which I found in Spain but they are like rocking horse manure. Mine is a spare but I would not let it go under
