Ty250a
belldane
Hi all. I am in the process of restoring one of the earliest Ty's and need an original second hand carb for it. The motor runs with the carb currently on it (not the right one) but is not running properly. No get up and go, bad acceleration and very very bad performance on full throtle. Any ideas where I can get one? or if someone has one they want to part with, please let me know how much. Thanks
The Ty250A came fitted with a TK carb, which was good for its time and if you can find a good second hand one will work well enough if you want to use the original posilube system. If you no longer have the oil system fitted remember to blank off the inlet at the base of the cyclinder. I would use a new Mikuni VM26 with 150 main and 35 Pilot, and maybe change, or clean the old reeds. There will be a TK for sale on e-bay soon! The TK was only fitted to the TY250A and was replaced in all subsequent years by a Mikuni and now with our latter day knowledge the VM 26 is the best and most reliable carb for this mark of machine. Go NEW and use 40:1 premix and for the 50 quid the money will be well spent and the performance spot on! I've rebuild about 30 TY250A's and never had a single problem with these carbs in reliability or woof! Mick Andrews enjoyed riding one of mine, and even signed the bike after winning with it.
Tony
  • 2 weeks later...
Hello Guys and Girls
I bougth a TK carb for a 250a from ebay but when I opened it up it was a mess. White milky liquid like clay came out of it everywhere. Petrol does not remove it! Any ideas please? Thanks
Can of spray carb cleaner, from the local auto parts store. Just don't get it on any of the rubber parts. Remove them first, and disassemble down to the parts you want to clean.
Thanks DGShannon
You would not believe what I found on the net. A carb specialist suggested that you put the carb into a pot and boil it in water for 10-15 minutes. Clears all the gunk out and just blow all passages. I did that today and the carb is fine. Just one problem though, See my posting on TY250 problem!!!! This is driving me mad!!!
