Running Problem?
razor
Old-ish one with the rotax engine. I think 1998 ish.
It kicks up alright, but as it starts to warm up it will not tickover, or if you increase the slide-stop to the point where it will tick over, when you rev it it revs its nuts off and does not drop back to idle quickly at all.
Seems lean, the idle mixture screw does not make much difference that I can figure.
Gday, the only other air leak issue that you might have is a leak from the magneto side crank seal. If the gearbox one leaks you get heaps of smoke and lowering oil level in the box. The maggy side one just leaks air when shot. If your carb/airbox cleans dont solve it look here next. Often you can see dirt sitting around the seal when the stator is removed if this seal leaks, but not always... You would have to remove the flywheel and stator (probably) to see clearly. A leakdown test will show it up if you have the gear to do this test.
Cheers,
Stork
