Yamaha Ty 175
simonk
Hi bought new kill switch black and white wire is earth the other wire goes to the coil do i just join this to the blue wire as seems to be only wire at the coil any one help? Got told yesterday to put wire on LT side ? any help would be much appreaciated cannot follow old wire as old switch disconnected thanks
Edited by simonk
If you have two wires on your kill switch connect the one to earth and the other to the LT (Low Tension) terminal of the ignition coil. This is the small flat spade terminal and will already have a wire on it coming from the points, so you will now have two wires on the LT terminal. The ignition coil is under the petrol tank.
