pop1wheelie Posted February 8, 2009 Report Share Posted February 8, 2009 (edited) Hi, I noticed a post from a while ago about rebuilding a TLR top end. I'm doing a top end on a TLR 200 myself and found that Honda discontinued the piston. Apparently a XR 200 piston with a thicker base gasket could work? Does anybody know if this modification works? Thanks! Edited February 8, 2009 by pop1wheelie Quote Link to comment Share on other sites More sharing options...
hondanut Posted February 9, 2009 Report Share Posted February 9, 2009 my xr200r barrel says 199cc whilst my tlr200 says 194cc, so there may be a difference, and i think the tlr piston is dished as well to give a lower compression, i know the at 185 piston is dished. Quote Link to comment Share on other sites More sharing options...
pop1wheelie Posted February 9, 2009 Author Report Share Posted February 9, 2009 Hi, Thank you for your response. If I'm not mistaken the only difference in pistons is the Compression Ratio? The XR CR is 10:1 while the TLR is 9:1. Would increasing the base gasket thickness work to reduce the CR enough to us the XR piston? Maybe I could reduce the dome of the XR piston to lower the CR? I now a lot of what I'm suggesting isn't very scientific but I'm kinda between a rock and hard place. Thanks again! Quote Link to comment Share on other sites More sharing options...
andy m Posted February 9, 2009 Report Share Posted February 9, 2009 Increasing the base gaskets will help, this is a common mod on a 250 to soften the power. You will want some slack in the cam chain and don't run it too tight as this can damage the head. Are rings still available? I need some in my 200. Quote Link to comment Share on other sites More sharing options...
pop1wheelie Posted February 9, 2009 Author Report Share Posted February 9, 2009 Hi, Thanks for the info! I'm thinking about using two base gaskets it should add around .035" to the thickness before squish, have you ever tried this? Should I put a little silicone between the two gaskets? Does the cam chain require less than normal tension if so do you know why? I just got a set of standard rings and I'm sure there're available the part number is 13011-446-811 (same # as XR200). Thanks!!! Quote Link to comment Share on other sites More sharing options...
andy m Posted February 9, 2009 Report Share Posted February 9, 2009 (edited) No I haven't done it but I know someone who has on a 250.I was told about a 250 using 5 gaskets. 2 gaskets would be fine, I wouldn't use silicone, make sure the surfaces are very clean. Chain needs to be same tension as normal, but you need some slack as you are in effect raising the head slightly. Tension it as normal making sure it is not too tight. Thanks for the part number. Edited February 9, 2009 by bo drinker Quote Link to comment Share on other sites More sharing options...
pop1wheelie Posted February 9, 2009 Author Report Share Posted February 9, 2009 5 gaskets! I'm surprised the motor still fit in the frame. hehe You're welcome for the part #. Thanks!!!!! 1 Quote Link to comment Share on other sites More sharing options...
helm Posted February 10, 2009 Report Share Posted February 10, 2009 Hi why not go for the 22Occ Big Bore KIt try stuart at BPS contact details on the honda trials site http://www.honda-trials.com/_sgg/f10000.htm cheers helm Quote Link to comment Share on other sites More sharing options...
pop1wheelie Posted February 10, 2009 Author Report Share Posted February 10, 2009 Thanks for the suggestion but I finally got an OEM piston. Quote Link to comment Share on other sites More sharing options...
