sherpa Posted December 15, 2003 Report Share Posted December 15, 2003 Have tried contacting Sherco with this question many times with no reply. I may have a problem with my email. Anyway, I have a 99 bike with a crack in the right fork leg axle bracket, just along where the pinch bolts are. The paioli manual I have gives no instructions as to the repalcement/removal of this item, or wether one is even available. (I know the bracket is removeable, but I dont want to cause more damage, without knowing the correct methods) The whole leg assy is very expensive. Any ideas/suggestions. Quote Link to comment Share on other sites More sharing options...
sherpa Posted December 23, 2003 Author Report Share Posted December 23, 2003 BIG JOHN: Thanks for the reply. Welding will most likely be the solution. I was hoping to find some one out there who had done the job before, or knew of a Paioli service center in the US. At this point, I don't even know where to go to get the part. Merry Christmas :santa1: Quote Link to comment Share on other sites More sharing options...
wayne thais Posted December 23, 2003 Report Share Posted December 23, 2003 Sherpa, Where are you located? I work for RYP, if you are in the US I am confident that we can do something for you. My email is wthais@rypusa.com Wayne Quote Link to comment Share on other sites More sharing options...
wayne thais Posted December 23, 2003 Report Share Posted December 23, 2003 Sherco has produced a "Fork Seal Replacement Manual" that has some very detailed instructions on how to take the lower fork leg off. http://www.rypusa.com/sherco/manual.htm Wayne Quote Link to comment Share on other sites More sharing options...
marky g Posted December 23, 2003 Report Share Posted December 23, 2003 Agree with you on the manual for Sherco's Big John. I've downloaded the whole the lot (over 2meg!) cut it to disc and took it to work to print out (save on my ink ) and I've now got it in a big old Folder in my shed :santa1: Thanks Wayne & Sherco, have a good xmas guys Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted December 23, 2003 Report Share Posted December 23, 2003 I think that Sherpa is noticing that the axle clamp is a separate part pressed on to the leg and he's wondering if it can be replaced. I don't think the fork seal replacement manual will help. I would imagine it could be done by a qualified machinist...you would have to know if it is pinned, or if any material is sweatted into it (like brass)...but I bet the real problem would be getting the part. I think you're in for a new leg. Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted December 23, 2003 Report Share Posted December 23, 2003 Sherpa, I just checked the parts manual, and there's no separate part# for the clamp. Just the complete leg. Quote Link to comment Share on other sites More sharing options...
sherpa Posted December 23, 2003 Author Report Share Posted December 23, 2003 Charlie, you nailed it!! I have a Paioli manual and it describes the bracket and even goes so far as to say that there is an o-ring seal that sometimes requires replacement. However, Paioli give no authorization or process to do the job. Further, they give no part info. Paioli recommends that the fork be sent to an "authorized" service center, of wich there are none that I know of in the US. Wayne, I have tried to send you emails three times with no reply. I thought perhaps I was having problems with my email provider, or maybe you were with yours. I will try again, Thanks :santawink: Quote Link to comment Share on other sites More sharing options...
charliechitlins Posted December 23, 2003 Report Share Posted December 23, 2003 Sherpa, Sounds like a computer glitch. In my experience, Wayne's replies are always speedy. Another good reason to ride Sherco. Quote Link to comment Share on other sites More sharing options...
wayne thais Posted December 29, 2003 Report Share Posted December 29, 2003 Ryan Young can provide the lower fork leg as an individual part, give him a call on 1-800-607-8742. Wayne Quote Link to comment Share on other sites More sharing options...
