colly Posted October 17, 2004 Report Share Posted October 17, 2004 i have a 1998, when i have a lot of fuel in it, and i lean it to a said, (on its stand) it drips pettrol out of a pipe on the carb, i was thinking to float might be stuck or something, why is this happening and how do i sort it out. also another question, there is a little window on the crank case, is this for the gearbox oil level, and how much oil do these take. thanks in advance Quote Link to comment Share on other sites More sharing options...
beta boy Posted October 17, 2004 Report Share Posted October 17, 2004 my carb use to do it i found out there was dirt in there causing the floats to stick so i cleaned it with carb cleaner and compressed air. as for the sight glass that is just to show there is oil in there. you bike takes 550ml of oil i find pj1 light clutch tunner works best after a long time of finding a good oil. Quote Link to comment Share on other sites More sharing options...
