edgas250 Posted February 13, 2009 Report Share Posted February 13, 2009 Ive replaced the o rings in the center section and after hours of trying i cant get the front pipe back into the center section with the new ones in!! ive cleaned the 2 reccesses out too but still wont go in!! any suggestions would be greatly appreciated!! oh and ive tried lubing it too! thanks Quote Link to comment Share on other sites More sharing options...
nzralphy Posted February 13, 2009 Report Share Posted February 13, 2009 Er... are they the correct size... you'll be amazed how many different sized orings there are. Try warming the ctr section and subsequently the orings... warm orings tend to soften a little and mah help you to fit the pipe. FWIW... Always fit Viton high temp orings - they don't melt Quote Link to comment Share on other sites More sharing options...
edgas250 Posted February 13, 2009 Author Report Share Posted February 13, 2009 I got the o rings from birketts, for the center section, i may try heating them up abit thanks Quote Link to comment Share on other sites More sharing options...
paul w Posted February 13, 2009 Report Share Posted February 13, 2009 (edited) a thin smear of silicon sealant usually helps me slip it on. just read that back, its all gone a bit leslie phillips.....ding dong. Edited February 13, 2009 by paul w Quote Link to comment Share on other sites More sharing options...
edgas250 Posted February 13, 2009 Author Report Share Posted February 13, 2009 all done now, thanks to the good old heat gun! next problem is wheel bearings, i ve only gone and hammered too hard and blown the one out leaving the outer shim in doh! Quote Link to comment Share on other sites More sharing options...
