2006 Sy250 Long Ride, Stuck Clutch.
g520
ya, haven't put them in yet
I don't find this too much of a problem, since the bike goes into neutral so easily,this was quite an annoyance on last bike because could never find neutral along with draggy clutch ....maybe yours is working better because, its an 06......mines an 03...possibly they fixed problem
what happens when you stall the bike in grar....will bike move with clutch lever in...in gear?
No, I went with the gear oil again. The clutch is good once I have broken it loose in the start of the ride. I usually start the bike in gear when it is warm, there is hardly any clutch dragging.
dammn!...maybe I should break down and get newer clutch plates!!
